| domain-suffix | Specifies adding a domain suffix. |
| domain_name | Specifies a domain name. |
| name-server | Specifies adding a name server. |
| ip_address | Specifies an IP address for the name server. |
| vr | Specifies use of a virtual
router. Note: User-created VRs are supported
only on the platforms listed for this feature in the
Switch Engine v33.1.1 Licensing Guide
document..
| vr_name | Specifies a virtual router. |
Adds a domain suffix to the domain suffix list or a name server to the available server list for the DNS client.
N/A.
The domain suffix list can include up to six items.
If the use of all previous names fails to resolve a name, the most recently added entry on the domain suffix list will be the last name used during name resolution. This command will not overwrite any exiting entries. If a null string is used as the last suffix in the list, and all other lookups fail, the name resolver will attempt to look up the name with no suffix.
Up to eight DNS name servers can be configured. The default value for the virtual router used by the DNS client option is VR-Default.
The following command configures a domain name and adds it to the domain suffix list:
configure dns-client add domain-suffix xyz_inc.com
The following command specifies that the switch use the DNS server 10.1.2.1:
configure dns-client add name-server 10.1.2.1
